does regearing...
ok thankyou
also tho, would it be overkill to just go straight to 5.29 right now, so for in the future when i get bigger tires i would still have power?, what am i expecting with 34`s and 5.29s
and how much are 5.29s, where can i find them, and how much is it to have a shop install them for me.
ok thankyou
lol wait, so are you saying with 34s and 5.29s i wouldnt be able to get on the highway?? @_a or would it be at 60 at about 3000rpm , and im still new to this stuff and i have some money right now, but do i have to get new gears for the front AND back? do they make gears for ifs? @_a how does it all work, i appreciate all your help
lol. yes you would do fine on the hwy lol. 60 at about 3000rpm is my ruff guestimate but its close!
yes if u gear the back you have to gear the front to match! if u ever plan to use your 4wheel drive.
yes they make gears for ifs! you will need 8" gears for the back and 7.5" gears for the front.
ok, sweet, thanks for your help
so i have to buy new gears for the front AND back, were you saying it would be about 150 bucks for the GEARS? or to just have them installed... hah sorry for all the questions, id just rather be well informed and not have to second guess anything.. which brand is the most recommended brand of gears that people have put in? and is it even that hard to install them yourself?
yes front and back!
150 an axel just for ring and pinion! install kits are like 100/150 also
i like precision gear. but imo most top brands are close to the same.
yes, im pretty mechanicaly inclined and i dont set up gears i leave that for the pro's. or somebody that you trust that knows what they are doing!
Brand is not as important as having them installed correctly. Besides most "brands" share manufacturers so in the end it doesn't make a big difference. I'd just avoid Genuine Gears. Bad reputation. So get Precision, Yukon, Motive whatever of those 3 is the cheapest since it won't matter. You buy a set of Yukons and it will be Motives in the box and vice versas.
Check out www.gearinstalls.com, he did my rear diff. His prices are reasonable but you will have to ship stuff to him which is inconvienent for some. At the very least read his site and educate yourself on what is needed to do the job right. They way you can make sure your local guy is doing a good job.
I'd say you are looking at a minimum of $800 to do both ends, but more like $1000 to do it right. Parts will be $500 between 2 sets of gears and bearings. Then labor
