Sponsored by: CARiD
Do you remove the crossmember, bracket, or just transmission mount?
Old Jul 22, 2018 | 12:01 AM
sae10w30's Avatar
When dropping the W49 transmission, do you remove the crossmember, the bracket, or just the transmission mount?
It seems there are three ways of disconnecting the back end. Which is best for dropping the transmission?
Also, do you locktite the bolts when you re-install? (What color?)
Attached Thumbnails Do you remove the crossmember, bracket, or just transmission mount?-bracket01.jpg   Do you remove the crossmember, bracket, or just transmission mount?-bracket02.jpg   Do you remove the crossmember, bracket, or just transmission mount?-bracket03.jpg   Do you remove the crossmember, bracket, or just transmission mount?-locktite01.jpg
Old Jul 22, 2018 | 06:02 AM
dropzone's Avatar
Fossilized
I'd remove the crossmember too, gonna be a PITA sliding the transmission out over that crossmember.
And than remove the crossmember and mounts from the trans
Old Jul 22, 2018 | 07:39 AM
L5wolvesf's Avatar
Yup what he said. Plus . . . Locktite Blue (red is kinda permanent).
ZXT
Jun 5, 2018 09:43 AM
hitsua
Dec 11, 2013 04:50 PM
83
May 25, 2010 07:59 AM
Batsoff
Nov 29, 2008 11:30 AM
