Crossmember mount bolt size
Old May 24, 2010 | 06:20 PM
83's Avatar
83
I want to take the t-case mount off the crossmember while the case is out of the truck. I don't have a wrench that will fit that big bolt. What size is it? Anybody know? FSM doesn't say...
Old May 24, 2010 | 06:32 PM
4Crawler's Avatar
What bolt is that? Typically has 4 small bolts that hold it in place, the big round thing is more of a locating piece, does not really come out.
Old May 24, 2010 | 06:52 PM
peow130's Avatar
Should be 4 12mm bolts..
Like 4crawler said, its more of a big locating thing.
Old May 25, 2010 | 05:21 AM
83's Avatar
83
Oook. So that big thing in the center isn't what's holding it on? I just need to find the 12mm bolts in there somewhere? Thanks everyone.
OC, how'd your t-case rebuild go (or did you start yet)? My parts get here today.
Old May 25, 2010 | 07:52 AM
4Crawler's Avatar
The sit inside the cross member around that big centering parts.
Need to fit a small socket into the holes in the bottom of the cross member to get to them (I swapped mine for allen head bolts):
Old May 25, 2010 | 07:59 AM
83's Avatar
83
Ok, the photo helps. Thanks 4crawler.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
