Sponsored by: CARiD
Do you have to re-gear for 35s?
Old Dec 11, 2009 | 09:14 PM
ToyotaSR5's Avatar
DO you have to re gear for 35s? I have 31s on a 92 4runner right now. What would happen if i put 35s on the stock diffs? Has anyone ever heard of someone not re gearing their diffs for 35s? Does it really cost like 1 grand for the master install set and 300 per diff wrench price to install them? I want to gear my truck out for offroading but all that throws my budget way out of wack. Any advice on this would be greatly appreciated.
Old Dec 11, 2009 | 09:42 PM
cutboggers's Avatar
You do not have to regear. You will want to as soon as you drive it.
It just takes all your power away, not as if we have any to begin with right?
you can get gears and master installs for $500-$600. and you will spend a pretty penny for the installs. make sure whoever does them knows what they are doing.
http://www.gearinstalls.com
go with 5.29's with 35's and you'll be happy
Old Dec 11, 2009 | 09:45 PM
Plumbrbob's Avatar
you will be a bogged a bit with such large tires I have ran 35-36's on 4.10's not to great in the wheel spin department.
you can regear on the cheap buy just the ring and pinion.....take the 3rds out and bring them to someone who knows how to set up gears...important make sure they know what they are doing...you can use your old bearings as long as they are not thrashed...now reinstall 3rds yourself BAM should cost you around $500-700 total depending on labor to set up gears I did mine for $470 both 3rds I have a guy localy who will set you up for a bill per 3rd
Old Dec 11, 2009 | 09:47 PM
Plumbrbob's Avatar
oh yea if your gonna wheel er make sure you have a solid pinion spacer
Old Dec 11, 2009 | 10:35 PM
ToyotaSR5's Avatar
Well that helps me out a lot. Thank you Plumbrbob and cutboggers. This forum has so many knowledgeable people its fantastic. I guess then ill throw the 35s on for now and do what you said about keeping the 3rds.
Old Dec 12, 2009 | 01:19 AM
Green_slime's Avatar
in 92 toyota had 488 gears available in runners and trucks with auto trans check your gears to see what you have if so you wont have to re gear for 35s if not the stock gears are 410s and you will want to re gear for 35s
Old Dec 13, 2009 | 03:00 PM
yotaman101's Avatar
It'll be pretty hard on the IFS to have 35's on there. You won't have to re-gear but its porobably a good idea. A good looking tire would be a 33, then it woulnd't rob as much power
Old Dec 17, 2009 | 06:57 AM
toyotabull's Avatar
in dallas craigslist there is a set of 5.XX gears under parts, just type in toyota gear
I ran 33, 36, and 38 on my truck, if you go bigger than 33 then get some gears and save your tranny some stress, I broke the input shaft.
Old Dec 17, 2009 | 08:35 AM
brian2sun's Avatar
Factory 4.88s are pretty rare so you probably have 4.10s. Even if you have 4.88s, you should really run 5.29s or 5.71s for 35s. I have 4.88s/33s w/ the 3.4L and would definitely want at least 5.29s if I had 35s. Once you get the tires, I'm sure you'll want to regear soon - you will loose a lot of power.
fountain
Feb 28, 2016 10:13 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
JookUpVandetti
Sep 24, 2015 02:58 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
