Sponsored by: CARiD
Differential breather
Old May 1, 2011 | 06:47 AM
Bones89yota's Avatar
I was looking around the forums for some differential breather setup pics I have a 89 pick up with a straight axle conversion but my rear diff breather is gone just a hole in the housing need some info on where to get parts and what I need to get I will try to post a pic of what I have in a bit but I am sure someone here knows exactly what I need to get to fix it thanks and also front and rear diff breather extending info
Old May 1, 2011 | 06:49 AM
xxxtreme22r's Avatar
http://www.4crawler.com/4x4/CheapTri...html#Breathers
Old May 1, 2011 | 09:32 AM
87AzRunner's Avatar
Take the stock breather out so you dont drop any debris into the axle housing
put the stock breather in a vise and take a pair of pliers and you can work of the
cap thats just clamped on around the breather and it reveals a nipple like the one
shown on 4crawlers page than just get some tubing and a hose clamp and your set. Don't even have to worry about threading in because came off that axle
Old May 1, 2011 | 09:46 AM
His problem is that he doesn't have the stock breather in there at all.
Simpler answer use one of these part numbers and attach a preferred length rubber hose and a universal oil breather filter on the end.
Nissan Part number 38323-C6010
Toyota 90404-51319: for 3/8” Barb
Toyota 90404-51026: for 1/4” hose
Nissan 38323-C6010: for 3/16” hose
or a standard 1/8" NPT to 1/4" hose barb fitting. as 4crawler mentioned it's not a perfect fit but his worked well.
Toyota part number for the OEM breather is 90930-03031
Old May 1, 2011 | 10:45 AM
wii_tarded's Avatar
Ace Hardware has that fitting for like a dollar. and some sturdy hose for around a dollar a foot. I got some 12mm id hose from work for free and then the fitting, works great.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
shooter86314
Jan 7, 2016 07:05 AM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
