Sponsored by: CARiD
Difference between stock tire sizes.
Old Sep 23, 2009 | 08:45 AM
mokancraig's Avatar
My '94 came originally with 225/75-15 tires, I know that 31x10.5-15s where an option. Was there any difference in gearing between these two tire options or was just a different speedometer calibration? Thanks!
Old Sep 23, 2009 | 09:04 AM
4Crawler's Avatar
Yep, different axle gears:
- http://www.4crawler.com/4x4/4R_TechI...tml#DiffRatios
Old Sep 23, 2009 | 10:01 AM
flashkl's Avatar
Unless the 31s were dealer installed...
Old Sep 23, 2009 | 01:53 PM
mokancraig's Avatar
Hmm, I guess I'll have to get under the truck and get dirty then. Thanks!
Old Sep 23, 2009 | 02:56 PM
24Runna's Avatar
Or look at the place card in your door jamb.
http://www.4crawler.com/4x4/ToyVIN.shtml
Old Sep 23, 2009 | 03:08 PM
mokancraig's Avatar
I took a look at the place card. It reads G254 on the axle code. According to this site, that means 8" with 4.556 gears. It also shows that being the ratio for the 31" option tires. Now I'm even more confused...
Old Sep 23, 2009 | 03:16 PM
24Runna's Avatar
Which means that whoever has put new tires on it over the years just put on OEM standard. They usually ask (because it is an option), or you have to request it.
Old Sep 23, 2009 | 03:19 PM
mokancraig's Avatar
So running 31x10.5s shouldn't be a problem? What about going to 32s or 33s, should I go to 4.88s for either of those sizes?
Old Sep 23, 2009 | 04:18 PM
24Runna's Avatar
33's shouldn't be a problem. I would do it as need basis. 35's I would go 4.88's.
Old Sep 23, 2009 | 04:24 PM
mokancraig's Avatar
Alright, thanks man! Hopefully this winter I can sell my other truck (Ford Ranger) and get something going on the 4Runner (engine, lift, tires, etc.)...
Old Sep 24, 2009 | 03:09 PM
williamt.'s Avatar
the vin tag on the inside of the door jamb also states the stock tire size... mine said 225/75 r15 which is equals roughly 28" tires. so i have 4.30s
its to the right of the GAWR and has front tire size above the rear tire size, which are obviously the same lol.
Old Sep 24, 2009 | 04:10 PM
mokancraig's Avatar
Mine says 225/75-15 as well, but the axle code reads 4.56s...
Old Sep 24, 2009 | 04:14 PM
4Crawler's Avatar
From what I have seen, the door sticker almost always shows 225/75-15 even on trucks that came with the 31" tires.
Old Sep 24, 2009 | 04:20 PM
mokancraig's Avatar
Interesting. I wonder what that's all about...
Old Sep 24, 2009 | 08:12 PM
williamt.'s Avatar
well... sorry bout that lol... hella weird.
Old Sep 25, 2009 | 05:57 AM
flashkl's Avatar
axle code isn't 100% either, the only way to truly tell is to jack a wheel up and spin it 720 degrees (open diff) and count the number of driveshaft revolutions
Old Sep 25, 2009 | 08:04 AM
mokancraig's Avatar
Before I buy tires I'll double check the axle ratios...
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
May 20, 2016 10:27 AM
DrZero
Jul 13, 2015 09:59 AM
