Cylinder leak-down test virgin needs advice
94 4x4 22RE x-tra cab
I have an overheating problem (see Hilux forum). I am about to perform a leak-down test on cyl #2, but I have not done this before. Any tips on how to proceed?
Remove the plugs and screw the adapter into the hole on #2. Set it at tdc on the compression stroke so that both valves are closed and pressurize to 60 - 80 psi. Listen to where the air is escaping. Intake means the intake valve is leaking, exhaust means exhaust valve, adjacent cylinder is a blown headgasket and oil filler cap means rings.
nframe
3.4 Swaps
Aug 16, 2015 09:03 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
