Sponsored by: CARiD
Cylinder leak-down test virgin needs advice
Old Mar 31, 2010 | 08:38 AM
ddwyer's Avatar
94 4x4 22RE x-tra cab
I have an overheating problem (see Hilux forum). I am about to perform a leak-down test on cyl #2, but I have not done this before. Any tips on how to proceed?
Old Mar 31, 2010 | 05:23 PM
eric-the-red's Avatar
Remove the plugs and screw the adapter into the hole on #2. Set it at tdc on the compression stroke so that both valves are closed and pressurize to 60 - 80 psi. Listen to where the air is escaping. Intake means the intake valve is leaking, exhaust means exhaust valve, adjacent cylinder is a blown headgasket and oil filler cap means rings.
Sleaker
Aug 26, 2020 06:03 AM
256mbaker
Jul 31, 2015 06:45 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
