Sponsored by: CARiD
Crankshaft Bolt-Help!!!!!
Old Sep 16, 2007 | 07:03 PM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
I am in the processs of rebuilding my engine, I have it out, intake and exhaust off, head off, now I am trying to get the timing cover off. First off is to pull off the harmonic balancer? My questions is, there is a bolt in the center surounded by 4 other little bolts, when I try to take this center bolt off my engine just turns over, I stick a bar in the holes in the pulley, and it bent a 1/2 inch thick bar trying to break it free and still wouldnt budge. How do I take this bolt off. Please help!!!!!
Old Sep 16, 2007 | 07:09 PM
toy_tek's Avatar
Take off the oil pan and wedge a block of wood between the crankshaft/rod and the block.
Edit: use an impact wrench if you have one.
Old Sep 16, 2007 | 07:12 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
stuff some clean rope in one of the cylinders so it cant compress anymore
Old Sep 16, 2007 | 08:21 PM
Green93's Avatar
I used a piece of angle iron. I drilled a hole in it and bolted it to the pulley with one of those 4 bolts. Get someone to hold it and use a breaker bar to undo the large center bolt. Hope this is clear. Good luck.
Old Sep 17, 2007 | 07:23 AM
DH6twinotter's Avatar
I did the same thing as Green93. Works good. If you have a manual, you can try parking it in gear.
Obmi
Nov 24, 2015 11:37 AM
charlie_fong
Sep 27, 2015 10:06 PM
Corvoid
Sep 14, 2015 10:10 AM
Iceman4193
Aug 28, 2015 08:43 PM
romex1
Aug 10, 2015 06:21 PM
