Sponsored by: CARiD
cold start up issue
Old May 2, 2010 | 02:19 PM
whitekingsnake's Avatar
cold start up issue
Hey fellas,
On cold starts the engine is suppose to idle up above 1k and then slowly drop as the engine gets warm. Well my does not. On a stone cold start it idles like it is already up to operating temp. It really has an erie feeling. The idle is smooth and sounds good.
I checked the AAC and the ohms were within spec I believe 50.1
I set my throttle lever like the FSM says loosen nut and screw the bolt till it just touches the lever and then 1/4 turn and lock nut down. I warmed the engine up and set the RPMs at 800. Just sounds better than at 750. Timing is correct with just a little advance to 10-12.
Everything else seems to be ok....any help would be appreciated.
Old May 2, 2010 | 02:24 PM
brian2sun's Avatar
What do you have?
Old May 2, 2010 | 03:01 PM
that might help huh.....sorry
86 4runner 22re 4wd stock
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Jnkml
Jul 6, 2015 01:20 PM
