code po336
code po336
I just replaced the head on my 1995 4x4 tacoma and now i get a code po336 is it possible that the distributor is out a tooth but i ask this because the engine runs fine no back fire. but the code causes the engine fuel cut out and dies you can keep it running by increaseing the throttle. i did the resistence test for the distribtor sensor and he crank sensor they check out fine. there were no codes piror to head replacement. tried resetting but code comes back.
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
