Sponsored by: CARiD
Frame ID Help
Old Mar 25, 2010 | 04:19 PM
VLP's Avatar
VLP
Frame ID Help
Well I recently bought a lifted toyota pickup. The body is from a 90, and the previous owner told me that he "Thought" that the frame is from an 85... Keep in mind it is not very stock so some things may have been changed along the way. I have talked to some other people who have thought by looking at it that the frame is still a 90 that has just been SAS'd. I don't know enough to tell the difference by dimensions etc. I am starting to plan future modifications and need to know what year the frame is, how do you easily tell?? If I have to I can go out and get pics of specific areas, just let me know. Thanks in advance.
(single cab)
Old Mar 28, 2010 | 05:57 PM
VLP's Avatar
VLP
49 views and no help...awesome
Old Mar 28, 2010 | 06:48 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Well... Pretty sure the last, or 1st of the VIN is on the P side front wheel well, stamped on the frame... If you're lucky it won't be ground off..
This is a IFS to SAS frame. See if it looks like yours... Notice the square tube and new hangers... And how they don't look factory...
Old Mar 28, 2010 | 06:50 PM
pics can help too ya know...
Old Mar 28, 2010 | 07:35 PM
VLP's Avatar
VLP
yup i will get some pics, just need to know what will help to id. I found the numbers in the wheel well on the frame, but it is not a vin i don't believe, the first letter is R, and it isn't enough numbers. my front end does look like that, just didn't know if people did that during RUF setups anyways. Any way to tell between 86-88 and 89+ even if it is SAS'd? i want to know what makes the difference between moving the hanger 11" and moving it 9.5" for later years on the 63 chevy spring swap... also measured my springs, fronts are 48" eye to eye (measured along spring, i am assuming this is how you are supposed to measure) and the rears are 52" (this is the one that confuses me)
Old Mar 28, 2010 | 07:47 PM
VLP's Avatar
VLP
these are the only 2 pics i have showing the front suspension mounts. I will get some good ones asap
VLP's Avatar
VLP
damn everythings dirty in those pics anyway, hard to see...
Old Mar 28, 2010 | 08:07 PM
"First, these springs offer a main leaf and a second leaf with the military wrap for added safety & strength. Secondly, when used as a front spring, the center pin position moves the axle forward 2" from stock, offering better tire clearance and the ability to run less lift and a larger tire. Third, these springs are roughly 2" longer than the stock Toyota solid axle front springs. A longer spring like this generally means more droop."
Front Springs
Custom Long Travel Front Springs
Misc. Spring Information
Old Mar 29, 2010 | 04:04 AM
VLP's Avatar
VLP
thanks for the posts, that last one seems pretty helpful. I am assuming that an 80's rear toyota spring was used in the RUF setup. And the stock 89+ rear 51" spring was left in the back w/blocks. I am pretty sure have a SAS based on the mounting hardware and extensive front end work. So all in all i am guessing that my frame is from an 89 to 94 truck and not earlier.
Any more info you can find is obviously apreciated!
thank you tried4x2signN for all your help so far!
Old Mar 29, 2010 | 06:47 AM
duh... I get the RUF now... For a moment I thought you were a Porsche mechanic
Old Mar 29, 2010 | 08:02 AM
VLP's Avatar
VLP
haha, i wish i could say that i owned a porsche
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
RDubya
Feb 10, 2017 04:46 PM
live4soccer7
May 11, 2016 06:52 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
