Sponsored by: CARiD
Code 24/31/25
Old Apr 10, 2018 | 09:49 AM
FunkMaster88's Avatar
Code 24/31/25
For the last couple weeks since I rebuilt the engine and fixed the wiring in my 94 yota 4WD 22re I’ve been getting a code 25 air/fuel ratio lean And it’s been idling rough Wanting to just suddenly drop in RPMs like the engines bogging itself out and popping in the exhaust like it’s missing but it’s not missing. previous owner had the fuel pump hardwired to the ignition and have an aftermarket cold air intake I went back to stock air box and I still get a code 25, I have replaced the O2 sensor and anything else I can think of and advice from here and I still have the code When I put the stock airbox on now I’m getting a code 24 (Intake Air Temperature Sensor signal) and 31 (Air Flow Meter signal Vacuum Sensor signal) and and still the code 25, it idles rough still, Even if I turn my idle control valve up it’s still slowly trickle down to about 500 to 200 RPM. Any thoughts, By the way even the Toyota dealership couldn’t figure it out
Old Apr 10, 2018 | 06:50 PM
old87yota's Avatar
You have started a few threads on this subject already.
In order to avoid confusion between threads, pick one one of the threads and update just one thread.
You can add more information by replying to this thread. This also puts the thread up to the top of the "New Posts" page.
I am in class right now (break), but I will look into your problem when I get home.
Old Apr 17, 2018 | 05:45 AM
Bad fuel pressure regulator?
What are the symptoms of a bad fuel pressure regulator at an idle in a 22re engine.
And what are the symptoms of a burnt valve at an idle also?
22REFORME
Feb 28, 2020 07:23 PM
Viet0ne
Mar 14, 2019 08:55 PM
mytoyota86
Oct 4, 2011 05:43 PM
89whitetoyota
Jul 19, 2010 08:51 AM
mmunoa
May 2, 2010 02:31 PM
