Sponsored by: CARiD
clutch question
Old Apr 12, 2011 | 09:12 AM
bmaurice's Avatar
clutch question
wats the best way to remove the bearing behind the flywheel. i dont want to go digging with a screwdriver..
Old Apr 12, 2011 | 09:38 AM
justin_4runner's Avatar
go rent a puller from the local auto parts store.
Old Apr 12, 2011 | 09:41 AM
jason191918's Avatar
Get a inside bearing puller. Prolly the easiest. Others use grease and/or pieces of wet paper and then tap a dowel/rod into the center to push it out (i've seen youtube videos of this, try searching for it).
Old Apr 12, 2011 | 09:48 AM
James Woods's Avatar
I tried that with a Corvette pilot bearing and couldn't get it to work.
Old Apr 12, 2011 | 01:20 PM
acicomp's Avatar
I know you have probably already solved this, but the easiest way to get it out is to pack the hole with grease and lightly tap a bolt in the hole that is slightly smaller than the hole. As you tap the bolt, it builds hydraulic pressure and forces the bearing out. I just did this on my truck several weeks back after we discovered that most pullers wouldn't fit the hole. I had someone tell me they use the ball end of the alignment tool that comes with the clutch kit instead of a bolt. Here is a pretty good write-up for the clutch replacement.
Hope this helps...
Old Apr 12, 2011 | 09:58 PM
bmaurice's Avatar
Hope this helps...
Wow! thankyou thats exactly what i needed. im replacing my 22re and dont have to much experience. i think collecting a bunch a good write ups is saving me. only problem i see having now is just finding where all the vacume lines and wires go.
Old Apr 13, 2011 | 09:49 AM
Are we still talking about a clutch job here?
Old Apr 13, 2011 | 09:56 AM
bmaurice's Avatar
no kinda went of topic i goto swap out the engine to
Old Apr 13, 2011 | 12:51 PM
sb5walker's Avatar
Here's a video using wet paper. I'm sure grease would work as well:
http://www.youtube.com/watch?v=1xuR7T8G1Ys
Don't forget to replace the rear main seal since it's right there.
Old Apr 13, 2011 | 01:57 PM
bmaurice's Avatar
whats the best way to put it back in? and kinda off topic but im swapping 22re's with a 94 22re 120k. how much will i gain from cleaning the fuel injectors? im just afraid once i start taking stuff off before it being in the truck im going to get lost. but im sure its goto be good to clean the efi.
Old Apr 13, 2011 | 02:40 PM
That is the video I have been referencing. To answer your first question, watch the vid. They explain it....
the1998sr5
15
Jul 14, 2020 08:35 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
upongame619
Aug 1, 2015 12:12 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
