Sponsored by: CARiD
clutch problems
Old Dec 11, 2006 | 09:30 AM
dushbin44's Avatar
Unhappy clutch problems
hi im new to this whole forum thing, so i hope you all bare with me. i tried searching for simular problems but i didnt have much luck. i have a 86 4x4 pickup, manual. for a past few month or so whenever i press on the gas hard when driving my engine revs and i dont speed up at all, no matter what gear im in. ive been told that my clutch is going out, which i figured, so if you have any info at all with what it might also be or how much work it takes to relplace my clutch will be great, thanks.
Old Dec 11, 2006 | 10:00 AM
rdharper's Avatar
If the clutch pedal feels normal, and the engagement point is high, and the symptoms got worse over time.... it is the clutch slipping.
I'd call around for estimates for fixing a "slipping clutch". That will tell you how much you might save if you do it yourself.
Old Dec 11, 2006 | 01:40 PM
dushbin44's Avatar
so then it would most likely be my plates in my clutch that i would have to replace?
Old Dec 11, 2006 | 01:51 PM
JEDI87's Avatar
The clutch disc is wearing and it probably won't last too much longer. Whe you replace it or have it replaced, make sure to have the flywheel resurfaced. You'll still have some burn marks on it from the burning disc. Make sure to get a good clutch kit, either Toyota, centerforce, etc... The kit should have a new pilot bearing and throwout bearing which should be replaced while the clutch is out anyway. When my friend had his done they wanted around $6-700 for parts and labor. I did mine for the price of the clutch which was $265.
Old Dec 11, 2006 | 02:25 PM
breknraj's Avatar
No offence, if I'm wrong, but it sounds as though you might be a mechanical novice.
If that is the case, I would not recommend trying to do a clutch by yourself, the first time out. If you have a KNOWLEDGEBLE friend or relative to help you, go for it. If not, get it done by a professional. There is way too much chance to seriously hurt yourself, if you don't know what you are doing.
Old Dec 11, 2006 | 08:22 PM
dushbin44's Avatar
none taken, i know enough i think, i do have a someone to help me who knows what he is doing though. ive already had to replace my head and head gasket. that was fun project. but if theres any little tips i u could give me that would be great.
Old Dec 12, 2006 | 05:59 AM
914runnerswap's Avatar
My clutch was incredibly easy to replace. Mostly b/c i took my 3.0 out of a truck and put it in a 4runner, so i replaced it while it was on an engine stand. That being said, not sure if there is a way to do it without pulling the motor or dorpping the tranny. Good luck!
Old Dec 12, 2006 | 08:00 AM
JEDI87's Avatar
I didn't have a jack tall enough so I drained all the fluid, unbolted the t-case and bench pressed it out. I did the same with the tranny. I just had my wife get a couple of bolts started while I held it in place. It took me about 1 1/2 hours to do it. Make sure to drop the rear of the tranny a little and will make it easier to get the 2 top bolts of the bellhousing. I just used some long extensions and my air ratchet.Make sure your clutch kit comes with an alignment tool, if it doesn't, be sure to get one.
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
