clutch problem and I cant seem to find the answer
I just bought a 1991 toyota 4x4 ext cab v6 manual transmission pickup. It has a brand new master and slave cylinder and it takes all my strength to put the damn thing in gear with the clutch pedal all the way to the floor but once it gets going it does fine sometimes. Any suggestions or answers would be very appreciated. Thank you
Yeah that what my brother was telling me about the sycroids but ill have to take it in for that since i don't know much about it. Im going to bleed the clutch tmrw and see if that is the problem or adjusting it if possible. I really appreciate the pointers man. I wish I knew more but im learning.
I dont think you have a synchro problem. The synchros just pretty much match the gear speed of the next gear that you are shifting into so you can shift with out any grinding of the gears and this is why if you shift into reverse when moving, it will grind because reverse is not synchronized. If all the air is bleed out of the hydraulic system and the pedal bracket is not cracked, what you have is an internal transmission problem, along the lines of a shift fork possibly, does it go into any gear when this happens? I highly doubt that all of the synchros are bad, and as I stated reverse is not synchronized so if it doesn't go into reverse when this happens, it is something else. Also when this happens, try either reving the engine a little and see if that works or shut the engine off and try to shift.
http://youtu.be/8KDuk2-4s6E
This video will help show you what is happening on the inside of a manual transmission.
sounds more like the shift forks are bent. and forcing it in gear is only making them worse. time to pull the trans out and apart to see whats going on, and rebuild it or just find one off craigslist and replace it... done.
Yeah, if you still cant get it into gear with the engine off then something internal is wrong with it. Rebuilding the engine is completely your call, if you have the money and time, then why not? After all that you will know that your truck will go for another 337K.
Yeah like you said there's something wrong. It works fine when its going down the road. The engine runs fine but has a oil leak somewhere but id like to have reassurance that my engine will be all new and rebuilt so I don't have any problems down the road. What's it usually run to have the tranny and engine rebuilt? Or a guesstimate.
I dont think that the pedal bracket is going to affect the shifter not going into gear with the truck off.
if the master is not adjusted or matched with the slave(I recall reading there were a couple different lengths of slave cyls on different trans) your clutch could not be disengaging all the way.
How hard do you have to push to get it in gear once the truck is off?? Once you do that can you take it back out of gear and how smoothly does it go back in. There will be some resistance sometimes when the truck is off to line the gears and synchros up.
I have to push the clutch to the floor and use all my strength to put it in first but once I get it going it has no problem shifting but it grinds going into 3 rd and reverse. When the truck is off it wont go into any gears without cramming it in except the reverse but it makes a clanking noise go.ing in
