Sponsored by: CARiD
check engine light
Old May 10, 2011 | 01:14 PM
Jamer77's Avatar
check engine light
Ok so this is it my check engine light goes on after about 5 minutes of using my ac so i turn it off and after about 30-60 seconds the light goes off and stays off as long as i keep the ac off if not the light pops back on again. Anyone has any idea what the problem is?
Old May 10, 2011 | 01:33 PM
MudHippy's Avatar
I think I might have an idea.
But first, what year/model/engine type are we talking about?
Second, have you checked for codes?
Old May 10, 2011 | 04:14 PM
Jamer77's Avatar
Thanx for the reply its a 86 4runner and has a 22re motor...didn't check for codes but I was thinking of going to checkers auto heard they do it for free
Old May 10, 2011 | 04:59 PM
MudHippy's Avatar
Oh an 86, then you can do it yourself for free, with a paper clip.
Jump the check connectors, then see if the check engine light displays any codes. If it blinks steadily without stopping there are none.
To decipher the flashes into codes read the following. Just ignore the part about TE1 because it used to be called T, and the codes because they're for a 93. Other than that the procedure is the same.
http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
Old May 11, 2011 | 02:44 PM
Jamer77's Avatar
Ok so i jumped it like you said and got a code 5 and 11. Is the oxygen sensor circuit the o2 sensor if so i changed it about 6 months ago and as for the (TPS) not sure what that is
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
