Sponsored by: CARiD
A/C No Green Light and Does Not Work
Old Nov 21, 2011 | 11:11 PM
jyama99's Avatar
Hi, I am trying to help my friend fix his a/c. It has no green light and no power going to the clutch. Charge is good. Can't find fuses or relays that control the a/c. I am knowledgeable on a/c systems but don't have a diagram on this set up. Any help will be appreciated.
1991 Truck 4X4
3.0 V6
Old Nov 22, 2011 | 09:49 AM
jyama99's Avatar
Bump??
Old Nov 22, 2011 | 11:36 AM
BMcEL's Avatar
AC and heater fuses are behind the glove box right below the heater relay:
If the fuse is good, check the low pressure switch:
http://personal.utulsa.edu/~nathan-b...19pressure.pdf
Old Nov 22, 2011 | 12:00 PM
jyama99's Avatar
Thanks, I will check today.
Old Nov 22, 2011 | 12:16 PM
swampfox's Avatar
Might be a bad low pressure switch.
Old Nov 22, 2011 | 03:32 PM
BMcEL's Avatar
You can easily rule out the pressure switch by shorting the following terminals if needed:
Old Mar 21, 2012 | 03:32 PM
azcheese's Avatar
parden my ignorance but is the purpose of the pressure switch to keep the clutch from engaging if there is no pressure in the system?
sharrack
Jun 26, 2015 09:33 AM
gog1968
Jun 22, 2015 05:55 AM
paxanders
Jun 21, 2015 06:29 AM
deuxdiesel
Jun 20, 2015 02:49 PM
LSUMatt1514
Jun 26, 2002 05:03 AM
