A/C No Green Light and Does Not Work
Hi, I am trying to help my friend fix his a/c. It has no green light and no power going to the clutch. Charge is good. Can't find fuses or relays that control the a/c. I am knowledgeable on a/c systems but don't have a diagram on this set up. Any help will be appreciated.
1991 Truck 4X4 3.0 V6 |
Bump??
AC and heater fuses are behind the glove box right below the heater relay:
http://img18.imageshack.us/img18/4215/heaterx.png If the fuse is good, check the low pressure switch: http://personal.utulsa.edu/~nathan-b...19pressure.pdf |
Thanks, I will check today.
Might be a bad low pressure switch.
You can easily rule out the pressure switch by shorting the following terminals if needed:
http://img848.imageshack.us/img848/8...sureswitch.png |
parden my ignorance but is the purpose of the pressure switch to keep the clutch from engaging if there is no pressure in the system?
