A/C No Green Light and Does Not Work
Hi, I am trying to help my friend fix his a/c. It has no green light and no power going to the clutch. Charge is good. Can't find fuses or relays that control the a/c. I am knowledgeable on a/c systems but don't have a diagram on this set up. Any help will be appreciated.
1991 Truck 4X4
3.0 V6
1991 Truck 4X4
3.0 V6
AC and heater fuses are behind the glove box right below the heater relay:
If the fuse is good, check the low pressure switch:
http://personal.utulsa.edu/~nathan-b...19pressure.pdf
sharrack
Jun 26, 2015 09:33 AM
LSUMatt1514
Jun 26, 2002 05:03 AM
