Sponsored by: CARiD
????bumed???? bout 22r motor swap
Old Jan 10, 2009 | 11:25 AM
mike mike 70744's Avatar
i have a 1992 toyota with a 22r fuel injected motor and i also have a 1989 with a carb motor can i put all my fuel injection parts on the carb motor
Old Jan 10, 2009 | 03:35 PM
yota8083's Avatar
IMO it would be better just to swap the whole motor as the head and cam characteristics are a little different on fuel injection than carb. Plus you will have the same amount of wiring to do either way.
Thomas
Old Jan 11, 2009 | 08:17 AM
what about if i change head and cam
Old Jan 11, 2009 | 05:52 PM
yota8083's Avatar
If you are going to change head and cam then put fuel injection on all you are keeping is the block. IMO this is pointless when you could just swap the whole motor and not have to pull the head off or any fuel injection wiring. I think what you are saying would me a lot more work than necessary.
Thomas
Old Jan 11, 2009 | 05:58 PM
GenXr's Avatar
You'll have less time swapping the FI motor over to the older chassis. You will have some re-wiring to do as well as the moving the ECU over. Not sure exactly but the fuel pump out put between the two motors may be different as well as the fuel lines.
It might be worth finding an aftermarket or custom wire harness to help you do the swap.
sandyota
Feb 4, 2021 11:16 AM
msane99
Jul 17, 2015 10:13 AM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Coreyr384
Jul 10, 2015 11:13 AM
