Sponsored by: CARiD
axle seals
Old May 31, 2013 | 05:57 AM
catfish21's Avatar
axle seals
Hello I'm doing my axle rebuild right now and I got the marlin axle service kit the big kit with everything needed and I need to know where the two small seals that come with the kit go, I know the bigger seals go inside the knuckle ball just the two small ones I need to know about thanks
Old May 31, 2013 | 08:12 AM
kawazx636's Avatar
I assume this is for a 79-83 pickup?? If so, You have it backwards. The smaller ones go in the balls on the axle housings (where the birfs slide into the axle housing. The larger ones go in the back side of the hub where it rides on the spindle.
This should answer you questions assuming that I understand you properly. IF not, pictures always help
Old May 31, 2013 | 08:14 AM
kawazx636's Avatar
oh, and I would try posting in the SUV & Truck Tech section under the appropriate years. You'll get more responses
Old May 31, 2013 | 08:36 AM
catfish21's Avatar
Hey man thanks a lot and you are right I just wanted to het all my ducks in a row I'm starting this project tomorrow
Old May 31, 2013 | 09:10 AM
kawazx636's Avatar
and be sure to label your knuckle cap shims when you remove them so that you put them back in the right location.
Old May 31, 2013 | 11:18 AM
catfish21's Avatar
Yeah ten four I'm pretty familiar with it all I just wanted really to make sure I had everything in this kit and about those seals
polo451
13
Nov 20, 2016 07:49 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
jerusry
Oct 19, 2015 05:28 PM
yoder519
Aug 17, 2015 07:12 AM
yourrealdad
Jul 21, 2015 11:13 AM
