Sponsored by: CARiD
Axle Interchange
Old Mar 28, 2007 | 04:34 AM
troyjmueller's Avatar
Axle Interchange
I have been researching toyota rear axles. I have a heavy ride with aftermarket dual rear wheels, and am aware that some axles were not the best. The 2wd p.u. has 5 lug hubs, the 4wd p.u. has 6 lug, the heavy-duty rwd dual-wheel axle has 6 lug.
The important factor is whether the axle is a non-floating type, semi-floating type, or full-floating type.
so, does anyone know if the 1979-1983 p.u. 4wd rear axles
a.) bolt-in interchange with the 2wd rear axles (diffential off-set, mount pad distance, etc,
b.) have a full floating, semi-floating, or non-floating design
I have found that the land-cruiser had options for semi-floating axles or full-floating axles. Does anyone know if the 1981-ish land-cruiser fj-60 full-floating axle is a bolt-in under the toyota 2wd or 4wd p.u.?
and, as a last note, does anyone have any experience in converting a 2wd p.u. to 4wd?
Old Mar 28, 2007 | 02:30 PM
tc's Avatar
tc
Only the dual rear tire axles were Full Floating (meaning, if you break an axle shaft, the wheel stays on and the axle shaft can be replaced without removing the wheel - right?), all other Toyota axles are semi-floating (meaning, if you break an axle shaft, the wheel stays on, but you have to disassemble the whole thing to replace the axle shaft - right?)
Rear axles are interchangeable. Not sure about the WMS distances though.
This might help a little:
http://home.4x4wire.com/erik/diffs/
If you explain a little better what you have and what you're trying to build, we could probably help more!
Old Mar 28, 2007 | 03:01 PM
JamesD's Avatar
The 2wd and 4wd are totally different. The only thing that is common is the 2wd 1 ton single rear wheel axle. They are both 8" diffs. Brakes, lug pattern and spline are different.
What heavy ride do you have? What wheels?
James
Old Mar 28, 2007 | 03:34 PM
4Crawler's Avatar
No go, the cruisers have offset rear diffs, pickups are centered.
You can get a full floater conversion kit:
- http://frontrangeoffroadfab.com/nfos...ec8fb4efce6fd6
Old Mar 29, 2007 | 07:29 PM
Thanks for the input. My "heavy ride" is a 20 1/2 Foot Sunrader RV with the original (single) (bad) 5 lug rear axle. It is "4wd", as there are two wheels on each rear drive axle (LOL).
Funny thing about it, the Motorhome gets better in-town mileage than my other driver, a 1983 mazda rx-7, at 13mpg in town, though worse on the road, at 20mpg compared to the rx-7's ~24npg. These are acurate figures, as I religiously record mileages and fuel consumed. (The rx-7 isn't running quite right - I have regularly gotten 17 in town on my last one, that died due to transmission & driveline u-joint failure.
I am building a new daily driver/work truck from another motorhome chassis that I've located, in the hopes of having a truck that might reach 30mpg on the road, 20mpg in town. Not sure if that is possible with a regular 2wd truck, or a 20' cab and chassis, with tandem axle. (not dual wheels), just two axles one in front of the other. 1976 20R engine, 4 speed (or 5 speed if I can get one to fit) manual tranny, and a 4.11 rear (drive) axle ratio.
13 foot 1-ton flat-bed Toyota truck, anybody?
Old Mar 30, 2007 | 05:10 AM
Thanks for the replies. My "heavy ride" is a 20 1/2 foot 1984 Sunrader Motorhome, with a non-full-floating rear axle and wierd dually wheels. It is 4wd only in the sense that there are two wheels (dually) per drive axle. It is currently my around-town daily driver (at 13mpg city/~20mpg highway)*wince*
Out of curiosity, on mileage, what can be gotten out of a 1976-1978 2wd 20R pickup with 4spd or 5 spd & 4.11 rear-end? I am building up a work truck/daily driver from another Toyota rv chassis that I recently bought. (1978 20' tandem axle). 13 foot Flat-bed, anyone?
By "Wheels", are you refering to other rides?
Drivers: 1983 Dolphin RV, 1983 Mazda RX-7, 1974 Mazda Rotary Pick-Up.
Projects: 1976 Mazda B-1600, 1978 Toyota Flat-bed, 1983 Mazda RX-7, 1985 Jeep Cherokee 4dr.
Old Mar 30, 2007 | 05:42 AM
tc's Avatar
tc
My '89 22R 2WD got 20.0000000 MPG on EVERY tank - highway or in town. It was a 4speed. Don't know the rear end ratio, but it was stupid tall.
I8URSVT
Oct 5, 2015 07:23 PM
Badfish740
Sep 29, 2015 09:35 AM
icentropy
Sep 10, 2015 05:03 AM
