Sponsored by: CARiD
Anti Lock Brake Issue
Old Sep 28, 2009 | 11:05 AM
ritewayco's Avatar
I have a 2009 Toyota Tacoma 4x4 with a 3 inch lift, and my front ABS system initiates when taking a corner at moderate speeds. Procomp does not have an answer to this problem. Any suggestions?
Old Sep 29, 2009 | 05:52 PM
jortiz2110's Avatar
Possibly the weight shifting since the height has changed. Did it do that before the lift?
Old Sep 29, 2009 | 07:10 PM
ritewayco's Avatar
The problem doesnt happen with the stock tires. I am focusing on the VSC system. There may be an issue with the wheel spin sensors. Thanks for replying.
Old Oct 5, 2009 | 03:20 PM
master tech1's Avatar
well u,ve already compramised the stopping abilty of the truck with suspension mods so why do u care if the abs works correctly or not. take the pump out and make the lines work without the pump. does ur abs light come on when problem occurs? even if it does't im sure theres a code in it. whats the code number and descrip? they are called wheel SPEED sensors. try cleaning them first if that doesnt work replace. do this only if u dont feel like getting code. another little tip before even turn a wrench check fuses and inspect wiring to speed sensors
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Jonny246
Jul 12, 2015 04:51 AM
