Advice on buying newer onroad/offroad 4Runner?
OK so yes I'm a newbie and have not done extensive searches, but I think my situation is probably unique enough to warrant a post. I do believe my topic will be valuable to the forum....
So here's my situation.....
I'm looking all over the country for something that fits the bill and I am mostly finding stock 4Runners in my budget, but occasionally I stumble across something like this
https://phoenix.craigslist.org/cph/c...636788644.html
Yes this one is a bit out of my price range, but is a truck like the one above (slightly lifted and upgraded suspension) gonna fit the bill for me better that a stock 4runner? Overall, will the maintenance costs of a slightly lifted vehicle be more or less for how I would use it? Is a slight lift even worth it for my situation? I know not all lifts are created equal, but I am confused and a bit ignorant about the ins and outs of it all. I guess I am already rambling a bit in this post, I've got more to say/ask, but I'll save it. Thanks in advance for any input!
- I'm a father of three and it is likely our family will grow over the next few years....(and we often need extra seats anyhow)
- We live off-grid 2 miles up a HORRIBLE old rutted logging trail and 9 miles from any pavement.
- My family and I drive to town about once a week or so.
- We've been making do with our 2001 Ford F-150 Crew cab 4x4 which is pretty much stock except it has all terrain tires that are snow rated and a winch.
- We have had to replace the whole front end suspension on the F-150 about once every year and a half or so because of what our road does to our truck.
- 3rd row seating is a must
- 4x4 a must (obviously)
- under 75k miles
- Must handle well on pavement (and ideally get half decent gas mileage)
- ideally locking rear diffs
- something that can stand up to the abuse of our driveway (having to replace the front end less often would be great)
- ideally some kind of upgraded suspension and possibly a slight lift?
If your drive way is so bad it takes out the front suspension of your Ford 150 anything you buy will pretty much be in the same boat .
Just what parts were being replaced ??
I am guessing your access road is not yours so any upgrades to make it more passable are not going to happen.
Maybe a 4Runner that has had a Solid Axle swap will hold up better Then you get into the quality of work done
Suspension and steering for the last 2 miles will most likely not be comfortable for highway use to some people
Two vehicles maybe one with tracks makes getting out in 3 feet of snow much easier
Under 75 ,000 may as well just look at 2017 and 2018 Toyota`s get driven
We've replace the upper and lower ball joints and tie rod ends on the f-150 3 times in 5 years and I believe the pitman arm and idler arm twice, also the hub assembly/bearings twice, I'm sure there's stuff I'm forgetting.... I'd have to look at the records again to be sure. I worked on it with a buddy once in his garage, but mostly I'm taking it to the local mechanic. I'm finding a few with under 75,000 as old as 2010. We plan to eventually improve the road but it will be at least a few years as there is legal recourse necessary to procure the "legal access"..... Plus then there's the actual time/energy/money needed to improve the road. We have considered the tracked vehicle option especially in the winter.... plowing is a whole other story and we have mostly resorted to the snowmobile when the snow gets too deep......
Countryhick
Oct 9, 2009 03:37 PM
