Sponsored by: CARiD
AC belt/idler pulley 22r
Old Feb 6, 2012 | 01:45 PM
turkeylips's Avatar
Hi. I am trying to replace an AC belt on a 91, 22r and have a couple of questions. If it is, will that allow the tension to be adjusted. Is the pivot bolt in the center of the idler pulley? And what position should the idler bolt be? Should it be snug to the bracket? Sorry it has been a while since I have had to work on this truck. I have a Haynes manual but it isn't much help. Thank you.
Old Feb 6, 2012 | 02:25 PM
maddad4x4's Avatar
You need to loosen the nut in center of the pulley.Then you con loosen the adjuster bolt to remove tension on the belt.
Old Feb 6, 2012 | 02:34 PM
turkeylips's Avatar
Thank you sir. Should the bolt that runs through the pulley (about 2" long) be tightened up to the bracket. The belt has been off for some time. Thank you.
Old Feb 7, 2012 | 05:02 PM
maddad4x4's Avatar
You tighten the bolt after you adjust the tension on the belt ,it locks the pulley in place.
Old Feb 8, 2012 | 08:30 AM
turkeylips's Avatar
Thanks for your help. I worked on a similar setup 8 years ago & just couldn't remember. It's tough getting old.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
