97 tacoma transmission wires
ok so i took out my transmission to replace my clutch, throwout bearing and pilot bearing and now i put everything back in and i have two plugs that i can find where they connect and i have two wires that look like a plug in thingy got ripped off of it. anyone know how i can find those wires or anyone have pictures or know what i should do if on of the plugs broke off. and one of the plugs comes of of the t-case.
Take some pictures, I can probably name these connections you speak of. If you want to look at FSM diagrams, check out http://www.ncttora.com/fsm/index.html
Ok...well the first pic isnt too great, but it looks like that wire is coming of of the harness? if so, it plugs into the other blue wire, the one coming off of the back of your t-case on the exhaust pipe side. This is your 4wd position switch.
I can't really tell the color of the wires that you broke the connector off of. Do you have reverse lights? It could also be your 4Low position switch. Do you have the connector that broke off or is it lost?
the connector is lost.
I know that the tcase one is the 4wd position switch but i dont know where it connects
one wire is green with a white stripe i think and the other is either yelow or white ill check tommorow
BeMiceElf
Oct 10, 2015 09:40 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
