Sponsored by: CARiD
91 toyota p/u
Old Nov 1, 2013 | 12:07 AM
poundh's Avatar
91 toyota p/u
Have trouble getting fuel from pump. The pump works but will not come on at all. Is there a way that I can put the pump on a switch or not. Will it work off a switch and run or what?
Old Nov 1, 2013 | 04:02 AM
Discombobulated's Avatar
Not sure I'm understanding that it works but won't come on? And sure you can put a switch to anything but why wouldn't you fix the problem so you don't have a switch to mess with.
But are you saying you have verified with another power source to the pump that it kicks on and will not with the factory wiring??
Give us a little more info
Old Nov 1, 2013 | 05:18 AM
poundh's Avatar
Switch
Some one did something to afm. Now pump will not come on.
Old Nov 1, 2013 | 07:24 AM
Scirocco16v's Avatar
When I was sorting out my pump issues, I ran a switch in-line to the pump & a jumper wire to the Battery.. if I recall, it was the blue wire in the wireing located under the passenger seat. once my pump tested fine I traced out the rest and found the break in the circut and did away with the by-pass.
Old Nov 1, 2013 | 08:02 AM
poundh's Avatar
Talking 91 p\u fuelnpump
Thank you for your help. Going to run it from a switch and hopefully it will run good until I can find what is wrong with it.
Old Nov 3, 2013 | 02:29 PM
poundh's Avatar
I found what it was it was the new pump stop working. I put another one in and it seems to be working fine. I need help whit getting the mass air flow meter working?
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
nick b
Jul 11, 2015 04:38 AM
