Sponsored by: CARiD
88 22re idles fine, dies when you try to go
Old Mar 5, 2008 | 04:28 AM
UberYotaNoob's Avatar
replaced plugs/wires, fuel filter and air filter. After that she would start just fine but when I put it in gear the engine will sputter and die. Checked mass air flow meter and readings are within spec. 5sp m/t. not giving me any codes.... any suggestions?
Old Mar 5, 2008 | 06:24 PM
just did the egr valve test, engine stalled when i put the intake manifold line to it.
Old Mar 14, 2008 | 09:28 AM
lotalucas's Avatar
What year is it. I have a 90 with a 22re and there's a butterfly valve at the begining of the intake right above the fliter. If there's anything wrong with that it can idle fine but just stall once you give it any juice. There's also an wire going to and from it and if either has a short anywhere same thing happens.
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
