Sponsored by: CARiD
86 Toyota Truck (Camper) oil leak 22RE
Old Jun 18, 2014 | 08:14 AM
notsobigkahuna's Avatar
I'm about to replace the front crank seal. the truck has 77k miles on it. how likely is it that the oil pump seal is leaking too? i'd like to go camping this weekend....
kahuna in kanada
Old Jun 19, 2014 | 07:22 AM
thefishguy77's Avatar
Are you sure it's the front crank seal? A lot of oil pumps start leaking before they go out. Have you cleaned the front of the motor really well and then watched where it leaks from. Sometimes that is the bed way to track an oil leak. Also I find simple green is a great way to clean a motor of oil. Good luck.
Old Jun 19, 2014 | 08:25 AM
i'm not 100% sure. it will be on a hoist tomorrow. i'd hope that a toyota oil pump lasts longer than 78k miles.....
Old Jun 19, 2014 | 10:32 AM
snobdds's Avatar
The pumps hardley ever go out, but the seal is what starts to leak.
I would just replace the front main seal and the oil pump oring.
Old Jun 19, 2014 | 03:11 PM
I would probably take his advice. He seem to know a little about these trucks
Old Jun 22, 2014 | 03:44 PM
Joe Hilux's Avatar
I have the same problem with my 3.0, however I can only confirm a RH camshaft leak, due to the fact that I can't get the crankshaft sprocket (gear) off the rod. I want to replace all oil seals and that oil pump o'ring.
matrad
Aug 26, 2024 08:21 AM
duckhead
170
Nov 13, 2017 06:07 AM
JF9243176
Oct 8, 2017 04:21 AM
DacodaYota
Sep 2, 2015 02:13 PM
JF9243176
Jun 24, 2015 04:53 AM
