Sponsored by: CARiD
86 toyota pickup sr5 sometimes runs like crap
Old Feb 26, 2011 | 04:14 PM
countrylivin's Avatar
Bought an 86 toyota pickup sr5 a few weeks ago. It has a 22re EFI with a 5 speed trans. The motor was completly rebuilt 20k miles ago. The problem its having is when you crank it up in the morning and drive down the road at first it kinda spits and sputters but once it gets over three grand it clears up and runs fine but if u stop and shut it off and go to crank it back up it trys to shut back off and if you give gas with it out of gear it just bogs down. if you start tappin the gas after two or three minutes it starts to clear up and you can pull off and once you get to three grand it clears up again and then it runs just fine. I just dont understand whats goin on with it! Please give me some insight. thanks
Old Feb 27, 2011 | 01:13 PM
rangerman04's Avatar
My 85' basically same truck has same issues so I changed all the basic stuff to no avail. Has a clicking coming from pass. Side dash, does yours also do this?
Old Feb 27, 2011 | 01:21 PM
GranVille-4crawler's Avatar
welcome to the forum... that being said pleaseee do a search. could be a bad afm. what all have you replaced on the engine. you said it was rebuilt before you bought it. got paperwork? when was the fuel filter last changed?
Old Feb 27, 2011 | 01:53 PM
I just replaced the fuel filter, according to other posts my maf may be bad causing the fuel pump relay to kick on and off. Does this sound correct?
Old Feb 27, 2011 | 02:02 PM
yeah thats prob the culprit. you should be able to test it with a multimeter, let us know what ya find out
Old Feb 28, 2011 | 12:53 PM
Mine doesnt click like rangerman04. What do you check on the maf?
Old Feb 28, 2011 | 01:27 PM
ok i did your homework for you. https://www.yotatech.com/forums/f116...esting-146662/ http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Mar 1, 2011 | 05:10 AM
Mine wound up being a hole in the bottom of the intake tube, bad part was I just had that thing off to clean the throttle body and neglect to repair before. Live and learn
Old Mar 1, 2011 | 08:25 AM
peow130's Avatar
Vacuum leak that goes away when the engine is warm?
Old Mar 1, 2011 | 06:17 PM
Well mine wasnt the maf. Any other ideas what it could be.
Old Jul 27, 2011 | 11:19 AM
killroo's Avatar
check cold start injector
arlindsay1992
Jan 23, 2024 01:34 PM
Yont283
Sep 23, 2022 08:06 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
