Sponsored by: CARiD
86 pickup 22r backfire
Old Nov 2, 2013 | 06:29 PM
jburress10@yahoo.com's Avatar
Hi. I have an 86 pickup 22r that is backfiring. The valves are adjusted and its a pretty new webber carburetor. Any ideas what it is that's causing it, and how might I fix it? Thanks
Old Nov 2, 2013 | 06:33 PM
kawazx636's Avatar
Checked your timing?
Old Nov 2, 2013 | 06:45 PM
Well the I just set the timing too. Everything I checked is seeming ok. I'm stumped
Old Nov 10, 2013 | 05:27 PM
Dale Rosales's Avatar
Try adjusting your air/fuel mixture
Sent from my ADR6400L using YotaTech
Old Nov 10, 2013 | 05:31 PM
Thanks dale. What should it be adjusted too?
Old Nov 11, 2013 | 11:18 AM
I'm not sure on a Weber I have an Asian carb if you look it up type in the search section: I'm sure you can find a form explaining how to do so. on mine I went and bought an air/fuel gauge
Old Nov 11, 2013 | 11:56 AM
Thank ya sir. Its a little confusing. The book says 31/2 turns out, but everything I've read on here suggests a lil over 2, so I'm a lil torn on where to set it. Seems to be fine now at 21/4, so I guess ill sit on that but it still seems like it could be better.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87blyota
Jul 10, 2015 04:31 AM
