Sponsored by: CARiD
86 to 81 driveline help
Old Dec 1, 2010 | 05:56 AM
elk4's Avatar
ok here is the deal i am wanting to know if my axel side of a 81 will side into the case side of a 86 or are the splines deffrent just need some info on it thanks for looking any help at all
Old Dec 1, 2010 | 06:16 AM
waskillywabbit's Avatar
What?
:wabbit2:
Old Dec 1, 2010 | 06:28 AM
dropzone's Avatar
Fossilized
try it, just make sure they are in phase, i think you are gonna run into other issues though
Old Dec 1, 2010 | 07:47 AM
4Crawler's Avatar
What exact part are you looking to swap?
Rear axle shafts on the '86 are longer (wider axle) than yours and of course the front axles are totally different (solid axle vs. IFS). Drive shafts on the '81 likely have 8mm bolts while the '86 will have 10mm bolts.
Old Dec 1, 2010 | 08:12 AM
elk4's Avatar
ok im talking about the front and i can get the flange for the case im trying to see if the case side of the drive line will slide into the axel side so basckly take half of the 86 one and put inside the 81 one what kinda issues will i have
Old Dec 1, 2010 | 08:28 AM
elk4's Avatar
and will it fit in side it
Old Dec 1, 2010 | 01:07 PM
elk4's Avatar
anyone have anything
Old Dec 1, 2010 | 02:51 PM
4Crawler's Avatar
The t-case flange should swap over and assuming the slip yoke splines are the same (count the splines and see), they should swap. I know the '84 and later slip yokes are all the same.
Old Dec 1, 2010 | 02:55 PM
dropzone's Avatar
Fossilized
Even if the splints match uP you will probably run into issues with length.
4" difference in the length of the two transmissiOns.
Old Dec 2, 2010 | 05:40 AM
elk4's Avatar
ok so i think i will just try it and let everyone know how it goes thanks for the info
ktm192k
Oct 1, 2015 08:47 AM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Odin
Sep 24, 2015 04:38 AM
djpg2000
Sep 7, 2015 10:36 AM
