Sponsored by: CARiD
86 4runner Flywheel bolt issue
Old Mar 1, 2016 | 10:48 AM
Nippon_surf's Avatar
In the middle of replacing my clutch. My 4runner has 133K, As there has been little off roading or abuse .. clutch had norma wear. So the Flywheel looks fine, and I didn't have luck breaking those bolts loose without Impact wrench.
My 3 options.
1. remount the new clutch & not resurface flywheel (i've read sanding is in option) -gamble
2. buy or rent impact wrench
3. Keep trying to leverage my 1/2" breaker bar to get it loose.
Thanks to anyone with suggestions.
Old Mar 1, 2016 | 10:53 AM
Any recommendations for a Impact wrench? air or electric!?! thanks
Old Mar 1, 2016 | 12:11 PM
MudHippy's Avatar
Save your money...for now. Hit 'em with a torch first. Some dumbass probably used red loctite on 'em. Get 'em hot enough, they'll come right out.
Old Mar 1, 2016 | 04:05 PM
Well I went and spent money and ended up with a used Snap On IM31 from the pawn shop. w$150 with guarantee Expensive yes, but 1/3 the price of new & BAM this thing is a keeper now thinking I will pair it with an onboard compressor for my expedition build.
Old Mar 1, 2016 | 04:11 PM
MudHippy's Avatar
So...it worked? You busted them loose with it? Was I right about the red loctite?
Old Mar 1, 2016 | 04:23 PM
Yes it worked easily. & no red loctite, this is the stock clutch I'm replacing.
btu44
Oct 7, 2016 08:03 AM
Henrythewound
13
Jan 12, 2016 07:18 PM
ToYoda49
Dec 27, 2015 03:04 PM
SunnyCoastSteve
Dec 17, 2015 06:52 PM
Zealous84milo
Dec 15, 2015 03:08 PM
