Sponsored by: CARiD
86 4cyl. axle housing accepts 92 third member?
Old Dec 7, 2010 | 10:05 PM
axleman's Avatar
Ive read the threads, and the tech I just want to make sure Im understanding correctly.Im not going to hav any problem bolting a third member from a 92 v6 4runner to my 86 4 cyl. axle housing.Am I on the right track? Any input is appretiated
Old Dec 7, 2010 | 10:17 PM
peow130's Avatar
Yes.
Search.
The 8" thirds from 79-95 are exactly the same (sort of)
And can be mounted in any axle..
I have a 3rd from a 79' in my 87 atm.
Old Dec 7, 2010 | 10:25 PM
axleman's Avatar
The sort of being the x factor ...as long as the 92 third member is a two pinion (non turbo) carrier right? wht about axle diameter? will this be an issue theyre both 27 spline shaft inputs
Old Dec 7, 2010 | 11:16 PM
axleman's Avatar
Anyone ?? i mean some one has viewed this thread that has some input???
Old Dec 7, 2010 | 11:45 PM
peow130's Avatar
You did read what i posted, right?
79-95 the 8" thirds are identical and can be swapped into any 8" third carrying toyota axle.
doesnt matter if it's two pinion or 4 pinion, the mounting pattern and spline count are the same..
Old Dec 8, 2010 | 12:29 AM
axleman's Avatar
ok cool thanks for your help
Old Dec 8, 2010 | 05:13 AM
rattlewagon's Avatar
Originally Posted by axleman
....theyre both 27 spline shaft inputs....
4wd Rears are 30 spline. 2wd rear 7.5" are 27 spline. Front IFS are 27 spline.
Old Dec 8, 2010 | 06:32 AM
dropzone's Avatar
Fossilized
Dude you gave it all of 51 minutes between your posts
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Poppie51
Jul 23, 2015 05:03 PM
