Sponsored by: CARiD
86 22r that wont idle and uses gallons!! of gas
Old Mar 22, 2010 | 05:37 AM
wjaur's Avatar
I just purchased a 86 truck with 86k original miles. since 08 it had about 1000 miles put on it. it starts but idles very rough and is blowing black smoke. at higher rpms it dosnt miss but lower it runs like crap. new cap rotor wires filter plugs etc. its carb is clean, at least in float bowl. float appears fines. vacuum lines seem fine. ive driven around 100 miles and used $50 in gas. What the heck is the problem? should i rebuild the carb? Please help.
warren
wjaur AT yahoo Dot com
760 805 1303
thanks
Old Mar 22, 2010 | 05:52 AM
fishon1213's Avatar
Might be running a little rich, LOL. I would assume a carb problem. I have an '84 22r and it was doing the same thing. Turned out to be the AAP(auxilary accel pump?) had a small leak dumping in way to much fuel. If you know a little bit about carbs, buy a rebuilb kit and go for it.
Old Mar 22, 2010 | 11:02 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
http://www.bluebassdesign.com/boonin/carb_faq/
And x2 on the above post. Pull the line going from the AAP of the carb, at the BVSV and see if gas runs out.
Originally Posted by Hilux
well... don't think I'll bypass it...
GP sorensen Autozone Aisin carb rebuild kit: $32 P# 96-615B
Napa AAP diaphragm: $15 P# 2-4014
Old Mar 24, 2010 | 03:39 AM
wjaur's Avatar
Thank you for your advice.
Thanks for the advice guys. you said to check the aap and you were dead on. runs like a champchamp.wjaurwjaur@yahoo.com
Old Mar 24, 2010 | 08:25 AM
sweet! ahhhh.... I love it when a plan come together..
Old Mar 29, 2010 | 08:11 AM
86yota321's Avatar
Can I jump in here with a question? I seem to have the same problem and wanted to check the AAP to see if it's leaking. Does the motor need to be running when pulling the line or will gas come out even if the motor is not running?
Old Jul 7, 2010 | 04:32 PM
Streetgrinder's Avatar
I would think it should be checked with the engine not running. Otherwise the vacuum would empty gas out of the tubing. That's a guess though. My truck has the same problem, so I need to check it out, too.
Old Jul 7, 2010 | 05:10 PM
swampfox's Avatar
the aap is a good place to start,you might also try checking the choke.
Old Jul 8, 2010 | 12:58 PM
I checked the AAP, the thing that's yellow on one end and black on the other. It seems to allow flow one direction but not the other. For $15 I think I'll replace it, and see if it helps. Didn't see any gas in the line to the vac port. I hear some kind of leak, so I think I'll replace the old vacuum lines while I'm at it, on general principles.
Old Jul 8, 2010 | 03:57 PM
That black and yellow thing is the VTV, looking at my book. I found the AAP, but it seems OK. That is a complicated bunch of emissions stuff there.
Old Jul 8, 2010 | 05:03 PM
thanks Gnarly4X, I think I'll replace it and see if it helps. Can't hurt, right?
Old Jul 10, 2010 | 04:47 AM
Looked at the AAP, and the diaphragm looked fine. Still running rich.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
_Nicco_
Aug 28, 2015 07:26 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Jnkml
Jul 6, 2015 01:20 PM
