Sponsored by: CARiD
82, carb or EFI is the question
Old Jul 1, 2006 | 07:26 PM
Thundermaxx's Avatar
First off, Hi everybody.
My carb is dieing on a steep incline and I was wanting switch to EFI (not sure that'll solve it though). But my question is how hard is it to switch to the EFI system or is there a carb that will or solution to getting the gas on those tuff hills. I know there's alot of guys with carbs so what am I missing.
Thanks in advance.
Old Jul 2, 2006 | 08:29 AM
tc's Avatar
tc
That's exactly why people go to EFI!
If it's a 22R, it shouldn't be too tough, but some changes will be required because you have the "older" block. You should try searching until someone who knows more etails chimes in...
Old Jul 11, 2006 | 11:17 PM
the_supernerd's Avatar
If you decide to switch to EFI, it might be easier to switch to the older fuel injection system from a 22REC. That is the fuel injection system used on Celicas. It would be easier on the early block. I believe you should also change to an EFI camshaft to do it correctly, but I could be mistaken.
Old Jul 12, 2006 | 10:37 AM
surf4runner's Avatar
prolly easier to get a FI 22re w/ ECU, etc and swap that in.
why not figure the carb prob? last time fuel filter changed? timing? many small (easy) things to check.
Old Jul 12, 2006 | 11:10 AM
4Hummer's Avatar
I have a complete EFI I can sell you, Includes upper and lower intake, fuel injectors, Cold start injector, all the sensors, throttle linkage, part of the main wiring harness, All you would need is a new set of gaskets, computer, wiring and a few hours of research here on YotaTech.
PM me if interested
kazuya2416
Apr 5, 2024 02:17 AM
makemusic116
Aug 2, 2015 05:23 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
Yota.Jay
Jul 23, 2015 08:08 PM
