Sponsored by: CARiD
newbie tire question
Old Jul 13, 2006 | 04:08 AM
jeremystephens's Avatar
i am installing a 3 inch suspension lift with the differential drop
i have a 96 runner limited it of course has the running boards
what size tires will i be able to run with the lift installed
without taking off the running boards
i was also considering some 1.5 inch wheel spacers to fill up the fender wells
any help here is greatly appreciated
jeremy
Old Jul 13, 2006 | 04:20 AM
emptypockets's Avatar
There are many threads on this topic, so I would suggest a search. What type of suspension lift will you be installing? I have 265/75R 16's on my 2002 ~ 32". Some people run 285/75R 16's ~ 33", but according to some, you'll need a body lift so the tires don't rub up front, along with some flatening of a pinch weld.
If you're planning on wheel spacers, you won't need the BL, but the opinions on that are mixed at best. Good luck.
Old Jul 13, 2006 | 07:29 AM
tc's Avatar
tc
I would say 33x10.50 on stock rims. I think it's 255/85-16 in metric.
Wheel spacers will make the running board interference worse - a lot worse. The farther out the wheel is, the larger the scrub radius. The only reason to add spacers or increase the backspacing on the wheel is to prevent it from rubbing the frame, but you're gonna hit other stuff way before you have to worry about that...
Old Jul 13, 2006 | 02:51 PM
i am going to use the toytec lift
has anyone removed the running boards and left the fender falres
how does it look
Old Jul 13, 2006 | 04:50 PM
i think im going to go with nerf bars instead
any suggestions
i like the 4 inch tubes
Old Jul 13, 2006 | 04:52 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
lots of people have removed the boards and left the flares. it looks fine in the rear but some say it looks sort of unfinished in the front. thats when you install mudflaps and youre done
Old Jul 13, 2006 | 08:22 PM
bob200587's Avatar
I second the 255/85 idea. If I had 16's thats what I'd get.
Old Jul 13, 2006 | 08:41 PM
rimpainter.com's Avatar
any suggestions
Avoid nurf bars unless you are an avid mall-crawler. For a similar price, you can get some rock sliders welded on (search "rock sliders"). Not only can you stand on rock sliders, but you can literally use them (if need be) for other purposes, such as sliding on rocks and using them as a jack point with a highlift jack - which you'll probably need anyway thanks to your 3" lift and larger tires.
PS: I got $70 for my running boards on ebay (just the plain chrome ones)
Old Jul 14, 2006 | 02:59 PM
if i go with the 255 85 16 tires
will i have to change the speed sensor or gearing any
also i need some front shock\strut recommendations
i think they are struts
djpg2000
Nov 11, 2020 04:56 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
