Sponsored by: CARiD
5VZ engine Cam Lash
Old Apr 4, 2011 | 06:13 PM
mstasiewicz's Avatar
5VZ engine Cam Lash
I have put on two rebuilt heads on my 5VZ engine. I now have a lot of valve train noise. I have checked all valve cam clearances and they are all within spec. The Toyota overhaul manual talks about setting up the cam lash. It says that you need to turn the moveable gear on the exhaust cam and place a bolt in the hole. Then install cam, tighten then remove the bolt. Now if you do not do this but all cam marks line up, can not doing this cam lash set up cause valve train noise? Thanks
Old Apr 4, 2011 | 06:59 PM
PismoJoe's Avatar
If you did NOT put the service bolt in, the you allowed the 2-piece exhaust cam sprocket to spring out of place. Not good, but you can turn it back if you just look at it and re align the sprocket marks, not to be confused with the 2 cam timing marks.
Check out this write up
https://www.yotatech.com/forums/f128...t-tech-226997/
Old Apr 5, 2011 | 12:41 PM
Easy enough to fix thanks on this. Still do you think this maybe the cause of all the cam train noise? Thoughts?
Old Apr 13, 2011 | 07:13 AM
PismoJoe's Avatar
Yes it would definitely contribute to cam noise.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
thefishguy77
Jul 30, 2015 10:59 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
