Sponsored by: CARiD
4wd on pavement
Old Nov 15, 2011 | 02:59 PM
YotaZac21's Avatar
4wd on pavement
I need to know if it is bad to drive on dry pavement in 4wd. I have a guy that keeps sayin it will mess up transfer case but i have this steep as road i go up to go wheelin at the top and i lock the hubs and go up in 4WL to keep rpms down alittle and so i can make it up. IS THIS BAD
Old Nov 15, 2011 | 03:04 PM
Alberta4x's Avatar
That's fine, just don't leave it in 4x4 all the time.
Old Nov 15, 2011 | 03:10 PM
creswellhick's Avatar
why do you have to put in 4wd to make it up pavement
Old Nov 15, 2011 | 03:16 PM
bob200587's Avatar
If you need the power of low range on pavement UN-lock your hubs.
Old Nov 15, 2011 | 03:28 PM
YotaZac21's Avatar
LOL its hella steep i can make it in first but its screamin cant use 2nd so i just put in 4 low and go up in 3rd
Old Nov 15, 2011 | 03:33 PM
scuba's Avatar
Unlock the hubs. No reason to be in 4wd on pavement.
2wd low is fine for the pavement.
Old Nov 15, 2011 | 03:36 PM
YotaZac21's Avatar
Oh ok lol i just locked them so i dont have to get out and lock them but sweet i thought it would hurt it
Old Nov 15, 2011 | 03:40 PM
maybe some gears in the future lol
Old Nov 15, 2011 | 03:45 PM
YotaZac21's Avatar
well i wanna do gears but i still want to retain my good gas milege and biggest tires i wanna run are 33s so what should i put in it
Old Nov 15, 2011 | 03:46 PM
BMcEL's Avatar
From a write-up by sb5walker on things to know about these trucks:
Sticky 4WD engagement - our transfer cases have a quirk where if you run it in 4wd on a surface with good traction (like a dry road or one that's just wet) the 4wd may later get balky at engaging. You can move the selector to 4 high or low, but it won't engage. The solution is to drive forwards and backwards repeatedly (on a slippery surface) until it engages. I've seen this take some time. The lesson is, make sure you run in 4wd only on slippery surfaces.
http://www.toyotanation.com/forum/sh...d.php?t=309179
Old Nov 15, 2011 | 03:50 PM
33s would go with 4.88s and my mileage is still good with 529s and 36s and all my engine mods and gears are so much nicer on your motor
Old Nov 15, 2011 | 03:53 PM
YotaZac21's Avatar
what do 4.88s run in price and if i do it the rear will get a elocker
Old Nov 15, 2011 | 03:56 PM
to be honest idk look it up and now your talkin money with a e lockes why dont you just slap a aussie or some other lunch box locker will save you money
Old Nov 15, 2011 | 04:03 PM
YotaZac21's Avatar
i was gonna pull one out of a totaled trd and what about a eaton true trac lsd
Old Nov 15, 2011 | 04:25 PM
ThatGuy1295's Avatar
And with the right gears your MPG's will go up considerably
Old Nov 15, 2011 | 04:59 PM
YotaZac21's Avatar
SWEEEEEET
Old Nov 15, 2011 | 05:18 PM
YotaZac21's Avatar
LOL who has 4.88s for sale
Old Nov 15, 2011 | 05:57 PM
bob200587's Avatar
Every gear place on the web....
Old Nov 16, 2011 | 03:01 PM
YotaZac21's Avatar
What has the best quality without breaking the bank
kawazx636
Oct 6, 2021 03:03 PM
tylermx71
Sep 29, 2015 08:49 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
May-39
Sep 6, 2015 01:05 PM
