Sponsored by: CARiD
4runner driveshaft lubing - which grease?
Old Jun 15, 2010 | 07:06 AM
Jave's Avatar
I'm trying to lube the driveshaft of my 99 4runner by following this guide: http://www.4runners.org/writeups/zerk/index.html
I'm having a hard time trying to figure out which grease to use. My manual specifies two kinds, NLGI 2 Lithium base grease for the u joints and for the slide yoke and double cardan joint, NLGI #2 Molybdenum Disulfide Lithium Based Chassis Grease.
I had real trouble finding NLGI #2 grease (only saw grease that said "meets NLGI specifications" and "meets NLGI 1.5 specifications". I finally found one tube that said NLGI 2 grease but doesn't say if it's Lithium base or not but it does say it's for lubing driveshafts.
I still can't find any 'Molybdenum Disulfide Lithium Based' grease that is NLGI 2. I only found one tube but it only said "meets NLGI specifications".
I found a bunch Mobil 1 synthetic grease tubes but none of them mention anything about NLGI specifications.
Do I really need 'Molybdenum Disulfide Lithium Based' grease or can I just use the regular NLGI 2 grease for both applications? Or, could I just buy that Mobil 1 synthetic grease?
Maybe I'm overthinking this but I just want to make sure I don't screw anything up.
Old Jun 15, 2010 | 09:22 AM
tc's Avatar
tc
I just use regular multipurpose grease.
Old Jun 15, 2010 | 09:32 AM
SpecialScottie's Avatar
x2
Old Jun 15, 2010 | 10:04 AM
snobdds's Avatar
Yep, regular old MP grease and have never have had a problem
Old Jun 15, 2010 | 01:20 PM
Jave's Avatar
So I guess it's not that important to have the exact recommended stuff then? If that's the case I'll just use the NLGI #2 I bought for both the front and rear.
Old Jun 15, 2010 | 01:52 PM
brian2sun's Avatar
That'll work fine. I've even used marine grade grease in mine (used to work at a marina) and it worked fine too.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
tobylab
Jul 12, 2015 12:53 PM
