Sponsored by: CARiD
3VZE Woes
Old Jan 14, 2007 | 06:41 AM
4runner_Jeff's Avatar
3VZE Woes
I have a 1990 4runner with the 3VZE V-6, 273,XXX miles on the engine. Timing belt, waterpump, pulleys and camshaft seals @ 250,000 miles.
Here is the problem, it is running rough (skipping).
I put new plugs in it yesterday and that did not help. While running I pulled the wires off at the distributor and pulling the 1,2,4 and 5 plug wires made it run rougher; pulling the 3 and 6 plug wires did not make a difference.
I am going to try new plug wires next followed by checking the compression.. although I did the wires at 240,000 miles.
The engine also periodically starts hard.
The engine is not smoking.
The oil pressure is good.
No gasoline in the oil.
When the engine is rev'ed it seems to run smooth, but it does seem to be lacking power.
I have read the theads about the burnt exhaust valves and the bad injectors.
Any thoughts to point me in the right direction and keep me from feeling too much pain at the garage?
Thank you.
-Jeff
Old Jan 14, 2007 | 06:58 AM
My814x4's Avatar
Do a compression test , that will tell you alot .
Old Jan 14, 2007 | 07:10 AM
As for doing a compression test what are the numbers that I am looking for?
I am guessing that the compression numbers vary a bit with engine wear?
... and what would low compression in jugs 3 and 6 point to?
... and what would normal compression in all 6 jugs point to?
Old Jan 14, 2007 | 07:56 AM
Cobra123089's Avatar
-Jeff
Try checking the 3 and 6 wires, you might have them backwards. When you pull a wire off the result should be the same for all the wires, a rougher idle.
Old Jan 14, 2007 | 09:06 AM
tc's Avatar
tc
http://personal.utulsa.edu/~nathan-b...fsm/index.html
With that many miles, I would be more prone to look for something "wear" related. I know Seafoam smooths mine out quite a bit. (Search on Seafoam - huge thread).
Old Jan 14, 2007 | 12:38 PM
littlerunner's Avatar
prolly got a burnt valve.i'm going thru the same right now with 303,000.soon as it dries up some here & can get room in the garage she's goin under the wrench
Old Jan 14, 2007 | 04:51 PM
.... also, for what it is worth, the mpg is unchanged by this rough idle- missing situation. Going to try the seafoam... can't hurt.....I suppose.....
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
