Sponsored by: CARiD
3.4 swap
Old Jan 31, 2016 | 07:28 PM
wfooffroad's Avatar
3.4 swap
I have a 91 pickup 5 speed with a tired 3.0 I just picked up a 98 4runner with a good 3.4 auto is it hard to put the 3.4 and the auto in place of the 3.0
Old Jan 31, 2016 | 07:59 PM
Chaser Johndoe's Avatar
welcome.
please use the search function at the top. 3.4 swaps are one of the most common engine swaps.
Old Jan 31, 2016 | 08:07 PM
scope103's Avatar
Many purchase the necessary harnesses, etc. from Off Road solutions. They have a pretty good write up of the procedure. http://www.offroadsolutions.com/tech...fe-conversion/ If that looks easy enough for you, do search around here for specific information on the swap.
Old Feb 1, 2016 | 08:22 AM
SacRunner's Avatar
It can be done. Easiest thing is to convert the 98 harness from auto to manual (you'll need the EWDs to know where to move the pins, plus you'll probably need new connector bodies), then buy a 98 M/T ECU. From there, a lot can simply be done by moving parts around, the trick is finding out what parts need to be moved and where they go. There is a bit of fab work to be done (making a new battery box and exhaust come to mind).
Then the real challenge is wiring everything together; the 3.0 and 3.4 use 95% completely different electronics, and you'll need to find a way to integrate the newer electronics (sensors and valves) to your older truck. Again, it can and has been done, you just need to do some research and find what needs to be done.
The 3.4 Swap sub-forum will become your new best friend: https://www.yotatech.com/forums/f160/ . Read through as many swap threads and stickies as you can; all the information you'll need is in there, although it is scattered around.
Old Feb 3, 2016 | 03:59 PM
StangBanger's Avatar
Awesome link man thanks
Old Feb 3, 2016 | 04:15 PM
slacker's Avatar
I have a L Hand battery Trey as well .. easy to install and chemical resistant .. so it makes it just that much easier .
Old Feb 3, 2016 | 04:29 PM
dropzone's Avatar
Fossilized
all the info you need is here
Old Feb 3, 2016 | 05:21 PM
donomite49's Avatar
Are you in the mountains or union county?
Edionne13
Dec 3, 2015 02:54 PM
Elshaunero
Engine Swaps
Nov 30, 2015 11:28 AM
95_n130
Nov 13, 2015 06:46 AM
Yotta88
Nov 9, 2015 11:10 PM
towotaguy
3.4 Swaps
9
Nov 9, 2015 06:40 AM
