Sponsored by: CARiD
2nd Gen susp. lift comparison/review
Old Dec 13, 2005 | 12:31 PM
hokiruu's Avatar
Hey My name is Uuri I have a 95 runner with totally stock suspension. I have been considering a 3-4" lift for some time now and want to know people's experiences with them all. Alot of the sellers aren't very clear on exactly what is in each one. The ones I am am considering if I don't just go for the little OME are:
Trailmaster
Tuff Country
Pro Comp
Super lift
Downey
AFAIK the Trailmaster and Tuff Country drop down the front arms with extention backets and use longer stiffer springs in back. What are your opinions on these different lifts? can someone who knows please explain the differences between them?
Old Dec 13, 2005 | 02:40 PM
Strap22's Avatar
Sponsoring Vendor
Trailmaster
Tuff Country
Pro Comp
Super lift
Downey
This "Little OME" is a great setup. In the picture is 4 Shocks, 2 Coil Springs, Ball Joint spacers, Steering Stabilzer, Rear Coil Spacers. this will give you 3-4" of lift over Factory height. The Downey Pan Hard bracket and Rear Control Arm Truss (Sonoran Steel now offers a much beefier rear truss)are all you need to get you started. I would recommend the PPV bracket and maybe extended brake lines if you use the rear coil spacers and lift the front to be even. The OME setup is a what I run on my '91 2nd Gen. For the price you can't go wrong. Total $614.04
Old Dec 13, 2005 | 04:57 PM
Randomness's Avatar
I'd recommend Land Cruiser coils in the back, new shocks, BJ spacers, and then a 1-2" BL if needed.
Old Dec 13, 2005 | 06:07 PM
Lysmachia's Avatar
I've got Landcruiser coils in the back and holy crap do I have articulation!
I only wish ToyTechLifts made stuff for 95 and before. They do 96 and after 4 runners and their lift kits for the 4 runner are 15% off...
http://www.toyteclifts.com/4Runner.html - You still might want to contact Dough at TTL and see if he has anything you could use...
Old Dec 13, 2005 | 07:10 PM
tc's Avatar
tc
Do you really need that much lift? What size tires do you want to run?
Here's a good review of how much lift for what tire sizes...
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Dec 14, 2005 | 09:23 PM
hokiruu's Avatar
thanks for the replies guys. for some reason i thought that the OME only was 2-3", but hey 3-4" is good news and actually would probably be enough. I don't think I'll ever run bigger than 33x11.5 or 12.5. For now I only have 31x11.5 Dueler Revos.
One reason I thought I might need some front lift after replacing real coils is that I want to run lower offset wheels. I have been told that even with my current tire size on a lower offset, I run the risk of rubbing. T/F?
The reason I want lower offset is to widen the track in order to add a little stability (especially if I lift it) and for looks. The OME is def. appealing, but I always explore all my options, so I just wanted to know about some of the others. I do not want to add a body lift. If I'm lifting, I want more clearance, plus I am not a big fan of how it looks. I mean, if I HAD to I would but I'd plan in order to avoid it.
Old Dec 15, 2005 | 04:54 AM
tc's Avatar
tc
With less offset (tires stick out more) and wider tires, body contact, not suspension/frame contact will be the issue. The easiest, most cost effective ways to prevent this are trim the fenders and/or a small body lift.
I shared the same opinions about the looks of a body lift until someone on here pointed out how covered the frame is on Toyota trucks and I looked at my 'runner with that in mind. It's not like American trucks where any body lift is going to show the gap between the frame and body. A 1" body lift will hardly show any frame - actually just enough to weld on some sliders.
Personally, I totally agree with the "as little as you can" lift philosophy, and it seems the best way to do this is combine a relatively small suspension lift and body lift.
Sticking with a narrower tire solves a lot of these problems too. I am getting some 33x10.50's this week (no lift in front, just fixed saggy springs in rear), there's another guy on here running 35x10.50's with little/no lift. I will probably do a 1" 4Crawler body lift this summer - too cold for that kind of work here now!
Old Dec 15, 2005 | 05:51 AM
Doc279's Avatar
Hey Randomness,
What model Land Cruiser coils ?
I already have the ball joint spacers
and a 1" body lift - currently using Downey HD rear coils
Old Dec 16, 2005 | 08:55 AM
AUYota's Avatar
check out 4Crawler lifts! His lifts seem to be more Toyota based than others
Go for some 1.5" ball joint spacers up front, and rise the torsion bar about .5-1"
http://www.4crawler.com/4x4/ForSale/...ntSpacer.shtml
plus some spring spacers in the rear
http://www.4crawler.com/4x4/ForSale/...ngSpacer.shtml
Then consider a good body lift. A one inch body lift after the above is a NICE lift. After a 2" body lift you'll need more work done.
http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
After that you can use 33" tires which also give an inch so that is 2+1+1= 4" Also the 33" 10.50's run alot better than the 11.50's in my opinion and the 11.50's don't really help all that much. You can't run 12.5 on stock rims, and I'm not a fan of changing rims. Don't get much good out of it for the cost, and trouble IMO.
Old Dec 18, 2005 | 12:49 AM
Keggo's Avatar
Search for a thread made by me... I give part numbers on landcruiser coils and whatnot... also there's a thread called something like "The BJ Spacer/Landcruiser coil thread"... or something of the sort, I believe Cebby started it...?
Old Dec 19, 2005 | 05:31 PM
birfieldbuster's Avatar
If you go with a bracket lift in the front (btw, dont do it) use one that has completely welded pieces, not the kind that reuses the old crossmember.
Yellow Sub's rig has the that kind and it is a headache to keep aligned.
Old Dec 19, 2005 | 05:42 PM
YeloSub7's Avatar
Ya it sucks, that's one of the many reasons why I am selling my runner...
Old Jan 10, 2006 | 07:22 AM
hokiruu's Avatar
just out of curiosity why do you advise against a drop bracket on the front? oh and i couldn't have possibly established myself as a noob any more clearly... i meant i actually have 31x10.5 not 11.5. d'oh! I am down with the skinnies and yeah i dont want tons of lift i guess. want to sun 32x10.5 for now so i don't think i'll need 4". with downey hd coils in back and ranked bars in front, will i have the option of fitting 33x10.5"?
Old Jan 10, 2006 | 08:46 AM
tc's Avatar
tc
I have 33x10.50 with NO lift and no rubbing. Make sure you have at least 4.56 gears though (came with 31's from factory)
Old Jul 14, 2007 | 06:31 PM
gen3_motorsports's Avatar
Im running a 93 4runner SR-5 4x4 IFS and A Superlift 4 1/2 lift kit, 35'' mickey thompson tires 2 3/4 backspace on the wheels no rubbing no limit on what I can clear
The kit includes everything for $2100.00 + install
I did the work my self so I saved $1000.00 on labor
The work can take 2 days
Old Jul 15, 2007 | 08:30 AM
FredTJ's Avatar
If you're going to run 33's, save yourself a bunch and install a 2" bl.
That'll work just fine, provide you with all the room that you'll need for 33's, keep your COG low (relatively speaking), provide room to push the tranny and xfer case up and provide room to push the gas tank up, all of which provides more clearance.
Spend the money that you've now saved on armor (bumpers, front and rear, rocker protection, idler arm brace, lower rear a-arm brace, gas tank skid, etc).
Doing this, you'll be set for about anything that you're likely to encounter anytime soon.
Fred
Jun 1, 2021 01:51 PM
Rasteirinho
Nov 6, 2017 03:40 AM
vanion2
Jul 29, 2015 06:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
