22rte 22rte swap is RUNNING !! Stock AFM running rich
The swap is complete!!!! I put my sock wiring harness back in the dash and now everything is operatoinal. I have the stock AFM from my 22re, is that going to cause the engine to run rich?
I swapped the RE computer to the turbo CPU. It will idle fine until I give it some gas, then it will load up and backfire a few times. then the idle will get rough for 10 seconds or so then smooth out to normal. I will keep searching through the posts for some more info.....thanks
You can`t use a computer for a regular 22RE on a 22RTE engine, there programed different. I was on ebay a few days ago looking through the toyota parts listings and there was a computer for a 22RTE listed, i don`t know how much it was though, but it might be what you need ?.
I used the rte cpu, stock 22re wiring harness, rewired the fuel pump to a separate relay and she fired right up, revs fine, drove around a little but the motor loads up and throughs out black smoke (to much fuel)
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
