Sponsored by: CARiD
22rte 22rte swap is RUNNING !! Stock AFM running rich
Old Jul 4, 2010 | 07:35 AM
JWillyG's Avatar
The swap is complete!!!! I put my sock wiring harness back in the dash and now everything is operatoinal. I have the stock AFM from my 22re, is that going to cause the engine to run rich?
Old Jul 5, 2010 | 08:18 AM
JWillyG's Avatar
I swapped the RE computer to the turbo CPU. It will idle fine until I give it some gas, then it will load up and backfire a few times. then the idle will get rough for 10 seconds or so then smooth out to normal. I will keep searching through the posts for some more info.....thanks
Old Jul 6, 2010 | 06:46 AM
JWillyG's Avatar
That sound right, I will adjust the AFM and check for vacuum leaks.
Old Jul 17, 2010 | 10:29 AM
Peach's Avatar
Wait a sec. what?
You installed a 22rte with a 22re harness and everything just plugged in with the only issue is that your rinning lean?
Old Jul 17, 2010 | 10:43 AM
myyota's Avatar
You can`t use a computer for a regular 22RE on a 22RTE engine, there programed different. I was on ebay a few days ago looking through the toyota parts listings and there was a computer for a 22RTE listed, i don`t know how much it was though, but it might be what you need ?.
Old Jul 17, 2010 | 10:49 AM
JWillyG's Avatar
I used the rte cpu, stock 22re wiring harness, rewired the fuel pump to a separate relay and she fired right up, revs fine, drove around a little but the motor loads up and throughs out black smoke (to much fuel)
Old Oct 5, 2010 | 05:20 PM
Double D's Avatar
any word on what happened here?
Old Dec 8, 2010 | 06:19 PM
wrxnefx06's Avatar
Did you use the stock 22re AFM?
vasinvictor
Jan 20, 2016 12:39 PM
puffin04
Jul 10, 2015 09:17 PM
viesail
Jul 6, 2015 10:16 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
