Sponsored by: CARiD
22re, rear suspension. truck leans to one side?
Old May 13, 2013 | 09:18 PM
AndyKrashYota's Avatar
So whats the deal. my truck has some major gangster lean in the rear. i measured the distance from top of tire to inner fender well and one side has about 1.5in more than the other. Ive seen a bunch of yotas that lean like that.
What could it be and how do i fix it
Old May 13, 2013 | 09:23 PM
Discombobulated's Avatar
Shocks, leafs or torsion bar adjustment, if shocks are good leafs are good alignment shop should be able to get it leaning away from the gangsta's pending you are working with IFS??
Old May 13, 2013 | 09:25 PM
yea. its IFS. its gotta be the torsion bar. how do i adjust that or should that be done at a shop
P.s. i want to do a lift. im thinking ball joint spacers and a shackle or add-a-leaf. what do ya think.
Old May 13, 2013 | 09:28 PM
off the subject. i just did the HG and water pump etc. but now im getting error code 52. its says either timing is off or knock sensor.
It was running rough so i loosened the dist while it was running and slid the dist until i got a good idle then tightened but the codes been going off still. ill check the sensor but i dont think its that cause im not getting any knocking sound
Old May 13, 2013 | 09:33 PM
If your going to do a spacer lift deal with the lean until you get that done you will need an alignment after anyway, as far as adjusting up to you unless you have a bay at your disposal hard to do in a driveway. Although I'm no expert at the torsion bar adjusting I don't think it's as simple as tweaking them with a simple turn and it's all good.
Search around on the ball joint spacers plenty of threads covering everything your thinking about doing, good luck
Old May 14, 2013 | 02:28 AM
J_yota22k's Avatar
what kind of motor you have? and HG meaning Head Gasket?
Old May 14, 2013 | 02:30 AM
J_yota22k's Avatar
if so did you make sure you number one piston was top dead center and made sure you cam set right if these are not set right youll have a rough idle
Old May 14, 2013 | 09:06 AM
highonpottery's Avatar
if your truck is leaning to the side in the REAR, it probably has nothing to do with your t-bars on the front suspension - it's more likely there is a problem with your leaf springs, like a broken one -- check the rear before the front.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jake28296
Jun 27, 2015 07:24 AM
cchinny
Jun 25, 2015 08:11 PM
Niameyrider
Jun 25, 2015 05:50 AM
