Sponsored by: CARiD
22re cuts out at 3000 RPM
Old Sep 28, 2013 | 11:05 AM
Jagman60's Avatar
Ive been fighting this for a month now. I have new injectors, new fuel pump, new fuel filter, new TPS, New ECT, New AFM, New ECM, Cleaned O2 senser, Cleaned throttle body, Checked and re-checked vacumn lines. Re-set valve lash.
Still, after warm up it will not go over 3000 rpm, just cuts out if you hold peddle down, surges then sputters, surges then sputters. Up until warm it runs fine. Idles fine also. and if you raise the throttle with it out of gear, she breaks up around 3000 RPM. Any ideas? I am starting new thread here but getting kind of desperate. Engine only has about 8000 miles since re-build. Looking for a new line of thinking.
Old Sep 28, 2013 | 01:24 PM
osv's Avatar
osv
i had similar symptoms, finally cut into the engine harness right around the plastic 90 degree elbow piece, and found corroded connector junctions, in the wires going to the injectors.
Old Sep 28, 2013 | 02:51 PM
Jagman60's Avatar
Thanks, Im gonna do that tomorow, Nothing to lose. Monday if I dont find it Im gonna limp on down to the mechanic shop and see if they come up with something. You know I talked to toyota and they told me they probably couldnt do any more than I could!! Because it wont hook up to their computer.
Old Sep 29, 2013 | 05:18 AM
Jagman60's Avatar
Darn, I worked my way through the wiring harness and finally found the splices (almost where the wires go through the fire wall) they were in good condition, shiny copper color and all tight. What Next?
Old Sep 29, 2013 | 06:32 AM
rokblok's Avatar
Just so I understand, if the engine is cold, it will rev fine to any RPM, just like normal? But once its warm, it starts missing at around 3000RPM? And won't rev higher than that until it sits and cools off?
Old Sep 29, 2013 | 06:56 AM
Jagman60's Avatar
Yes, that seemed to be the symptoms, but I just pulled the fuel filter (only 8 months old) and mud and rust came pouring out. I have a feeling this might be it since I replaced everything else. (yes I feel like a dumbass) I think I will drop the tank while I'm at it. Cant get a new filter till tuesday I guess hope this is it.
Old Sep 29, 2013 | 07:41 AM
rokblok's Avatar
I was thinking fuel filter myself. Since it may be "time it's been running", and coincidentally "time to warm up", if that makes sense. It runs for a bit til the filter becomes clogged, since it may "back-flush" when it sits for a bit. Just a thought anyway. Hopefully that's the problem, but keep us informed.
Old Sep 30, 2013 | 04:17 PM
Jagman60's Avatar
Dropped the tank and it was full of crap. The screen was disintergrated and all the stuff was in the pump. Just for information to others, that screen doesn't last too long.
montanatruck
Feb 26, 2017 07:07 AM
coffey50
Jul 28, 2015 10:55 AM
kcaudill
Jul 20, 2015 12:06 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Nickdigg
Jul 7, 2015 06:04 AM
