22r vs. 22re
This is the peice I would be trading
If I had a Heep, I would trade for a factory 22r-te. if it looks factory, most likely it is. get the VIN, look it up. there should be other designations that will tell you for sure if its factory.
#26
I know I've said is before, but you guys rock. On all the diesel forums I am on, it would take me 4 days to get all this info. Thanks. Maybe I'll see some of you guys on the trails soon, in a Yota
#32
You didn't finish your post but I'm assuming your asking if you can run an re head on a rte turbo motor? Yes you can, lots of people do it. I'm pretty sure mine has a non-turbo head on it. It just raises the compression a little bit.
#33
5spd turbos are rare. They had to be special ordered from Japan, as far as I know. He could have swapped in a 5spd, though.
#34
Thanks.
#35
