22r vs. 22re
Whats the diffrence between the 22R and the 22 RE motors?:think:
One is electronic fuel injection, one uses a carburetor.
same motor, carb/efi
22R = Carb 22RE = EFI, more power, more reliability |
wich one is wich?
By the way, awsomeness with the fast replies
Originally Posted by 4banginRunner
(Post 51026338)
Originally Posted by toyota4x4907
(Post 51026342)
I don't know man, EFI has more things that can go wrong, wiring and all. EFI has more power and better efficiency.
I have a firend that had an 84 pu and he says it was a 22r with mechanical fuel injection. How does this sound?
EFI started in 85
84 would be 22R carb , mechanical fuel pump maybe? |
HUH. anyways, you guys are ALOT quicker with the responces that the guys on the diesel forums. I am glad to be tryin to trade my Jeep for a Yota!:rockin:
And you guys got awsome smilies |
I like efi better. I always had problems with carbs.
Edit: They are both good engines. And they both will last 400k miles+ if you take care of them. |
I like the carb for simplicity but I haven't seen my truck run since it got really cold here.
22R is carburetor and uses a manual fuel pump
22RE is fuel injected, uses four injectors... The wiring is different on both: I used my intake, exaust, off my 22RE (88 model) and put it on the block of the 22R (87 model) |
The EFI can be more finicky with the vacuum leaks and wiring and whatnot. I'd still rather have EFI than carb, tho. :)
efi all the way better economy more reliable and 9 times out of 10 more powerful and the 22res have different ignition systems too
What about a 22RE turbo motor? Was there ever one offered?
ive seen a couple customized with a turbo but have yet to c one stock on a 22re but that doesnt mean they dont exist
Yes, they made a 22re turbo. They are pretty rare, but there are quite a few members here with them.
I got a guy that say's he has a Yota he says is a turbo motor he wants to trade for my Jeep and I was just woundeerin if it was factory.
hmmm learn something new every day
